Custom Nesting Report Templates
TylerJ804
TylerJ804
Hey guys,
Has anyone successfully made a template that would allow Fusion Nesting Reports to output just the sheet name, sheet layout and parts list? Preferably in a landscape orientation rather than a portrait?? I messed around with the HTML document and I was able to get rid of a lot of the extra data from the output, but I still find myself going through the document and selecting which pages to actually print.
Also, is it possible to somehow move the part number from the corners of the part representation to the actual center of the part so you could see it better??
Thanks!
woorijung
Hi Tyler,
Looking for this?😀
https://a360.co/42Aif2Q
FusionManufacturingMublio
Hi @woorijung, is this a custom nesting report with the abovementioned improvements? Would be extremely useful for me too. Can you enlighten me bit further how to implement this?
TylerJ804
This is perfect, thank you so much!
TylerJ804
Upload his HTML file to your Assets - NestingReportTemplates Folder on your F360 Data Panel, and then generate a report from a nest and select the file in the drop down as the template.
Will try, thanks !!!
Installed the template, big improvement.
However, the numbers on the parts are still unreadable due to low resolution and the fact that the numbers are placed right at the edge of the part. If there are many parts present, the names of the parts become smaller, and unreadable too. Therefore, the reports are unuseable for the operator... Did you manage to fix this in any way? Tried playing around with printer settings, but this does not help.
Also, the
