Tool Library Request.
HughesTooling
Consultant Consultant
HughesTooling
I've asked about this before. To help with searches, can whole number drills\cutters display a trailing 0? So, as an example if you search for a 5mm drill you get probably 20+ cutters because anything ending in 5mm is listed. If you could enter 5.0mm you'd only get 3 cutters.
For comparison, searching for a 5.2mm give just 1 cutter.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
FrodoLoggins
Also the ability to find an 1/8" end mill by typing .125 like with the old tool library. If the fraction doesn't end with a 2, 4, or 8 I'm probably lost...
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
HughesTooling
@seth.madore Is this down as an improvement. I did wonder if this is more of a problem working in mm rather than inches but @FrodoLoggins sees the same problem working in inches.
Thanks Mark
Mark Hughes
seth.madore
I'll take a look and open one if needed!
Seth Madore
seth.madore
I did not find anything logged yet, so I've opened up CAM-44943 to investigate this improvement. Thanks for poking me!
Seth Madore
