Creating a custom endmill or editing a form mill
dynamic.machine
Message 1 of 10
dynamic.machine
Is there any way to create an endmill with custom dimensions?  I have been able to create a form mill with the desired geometry, but can't use it as an endmill... "invalid tool type for milling".  Can your CAM developers add a 'shoulder diameter' option to the lollipop or slot mill?  I am trying to undercut a tapered wall with a lollipop mill and the clearances are pretty tight.  Would love to be able to accurately model the tool for simulation purposes.  Once a form mill is created, is there any way to trick Fusion into treating it as an endmill?
Replies (9)
Message 2 of 10
Steinwerks
Have you tried adding Shaft sections? Can you link the tool here so we can see what you're trying to create?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 10
dynamic.machine
Thank you Neal...  Here is a link to the tool... http://www.harveytool.com/ToolTechInfo.aspx?ToolNumber=22832-C3
The picture shown is generic and doesn't represent the actual tool geometry.  I have attached a sketch with the dimensions.
I hadn't tried adding shaft sections until I read your reply... I have since tried adding a shaft and I am thoroughly confused on exactly how that works.
Message 4 of 10
Steinwerks
Here's how I have it set up:
Unfortunately this still doesn't actually show up as a true lollipop mill with the ability to undercut. I'm not sure why, but perhaps @fonsecr or @cj.abraham could chime in? I know it's doable, as I have done it before, but I suspect something in the representation isn't working correctly.
Edit: I just noticed your definition thinks your tool is 0" in diameter. Try changing that to .5" and see if it will let you use the form tool then. I believe you've confused the CAM Smiley Wink
Neal Stein
Find me on:
Message 5 of 10
Steinwerks
Alright I imported the Harvey DXF (I miss the days when they just had a dimensioned drawing on their tool page) and defined at .5" it seems to work fine:
Edit: I've attached the file.
Neal Stein
Find me on:
Message 6 of 10
dynamic.machine
Thanks for taking the time to look into this for me.  How did you go about importing the dxf from Harvey?  Did you just use the dxf to create a form tool?  I opened up your .f3d file and copied the tool you created into the cam for the part I'm working on, but still get the "invalid tool type for milling" error.  I am trying to use it in both a 3d adaptive and 3d contour toolpath.  I recall reading somewhere that form mills can only be used on 2d paths... is that correct?  If so, I wonder if there is a way to trick Fusion into treating it as an endmill.  The shaft section example you sent earlier may work.  I will give it a try in the morning.  I really appreciate your help.
Thanks... Mike
Message 7 of 10
Steinwerks
Ah, yes the form tool functionality is very limited unfortunately.
As far as importing the DXF, on the right-hand side of the tool bar under the Insert button you can insert a DXF as a sketch. I did use it to create the form mill.
Neal Stein
Find me on:
Message 8 of 10
cj.abraham
@Steinwerks To address your tool definition question, it looks like the shaft diameter of 0.5" and a lollipop diameter of 0.5" is creating a ball endmill. Try making the shaft diameter on the cutter tab smaller and then adjust the shaft segments accordingly.
Message 9 of 10
butch_berney
I have a form mill created, but want to change it. I can't seem to find a way to change the profile once it is created though.
Can an existing form tool be changed?
The only way I can see how to do it is to create a new form mill. Not the end of the world, but it seems like that information should be editable somehow.
Thanks 🙂
Message 10 of 10
Yes, I have found the form tool function to be useless.   Aside from creating more accurate simulations and looking pretty, a custom form tool is a waste of time.
I would LOVE to be able to cut 3d geometry with the form tool profile.
