Cosign cnc machine
Cosign cnc machine
ferranti_boy
Message 1 of 9
Cosign cnc machine
ferranti_boy
are there here who use fusion 360 to control a cosign cnc
what post do you use to control it
regards
carlo
Replies (8)
Message 2 of 9
Richard.stubley
Hi @ferranti_boy,
I cant see that we have a post in our generic library. Looking on the internet I can find much information about the Ggode it requires.
Seeing that its a router my guess would be its fairly standard ISO Gcode, I would try with something like the GRBL milling post processor, this is already populated with options to turn off the M6 tool change command for example so should be a good base for you to work from.
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 3 of 9
ferranti_boy
sorry for the late response
here is an nc file that is sent to the machine
(Cosign)
N1 M6 T7
N2 M13 S25000
N3 G0 X762.7 Y510.
N4  Z14.
N5 G1 Z1. F200
N6  Y857.3 F2000
N7 G3 X760. Y860. I-2.7 J0.
N8 G1 X662.7 Y860.
N9  X760.
N10 G3 X762.7 Y862.7 I0. J2.7
N11 G1 Y1005.
N12 G3 X755. Y1012.7 I-7.7 J0.
N13 G1 X110.
N14 G3 X7.3 Y910. I0. J-102.7
N15 G1 Y110.
N16 G3 X110. Y7.3 I102.7 J0.
N17 G1 X755.
N18 G3 X762.7 Y15. I0. J7.7
N19 G1 Y157.3
N20 G3 X760. Y160. I-2.7 J0.
N21 G1 X662.7 Y160.
N22  X760.
N23 G3 X762.7 Y162.7 I0. J2.7
N24 G1 Y510.
N25 G0 Z14.
N26 M13 S22000
N27  X762.5
N28 G1 Z-0.3 F200
N29  Y857.3 F2000
N30 G3 X760. Y859.8 I-2.5 J0.
N31 G1 X662.5
N32  Y860.2
N33  X760.
N34 G3 X762.5 Y862.7 I0. J2.5
N35 G1 Y1005.
N36 G3 X755. Y1012.5 I-7.5 J0.
N37 G1 X110.
N38 G3 X7.5 Y910. I0. J-102.5
N39 G1 Y110.
N40 G3 X110. Y7.5 I102.5 J0.
N41 G1 X755.
N42 G3 X762.5 Y15. I0. J7.5
N43 G1 Y157.3
N44 G3 X760. Y159.8 I-2.5 J0.
N45 G1 X662.5
N46  Y160.2
N47  X760.
N48 G3 X762.5 Y162.7 I0. J2.5
N49 G1 Y510.
N50 G0 Z14.
N51 M13 S25000
N52  X1522.7
N53 G1 Z1. F200
N54  Y857.3 F2000
N55 G3 X1520. Y860. I-2.7 J0.
N56 G1 X1422.7 Y860.
N57  X1520.
N58 G3 X1522.7 Y862.7 I0. J2.7
N59 G1 Y1005.
N60 G3 X1515. Y1012.7 I-7.7 J0.
N61 G1 X870.
N62 G3 X767.3 Y910. I0. J-102.7
N63 G1 Y110.
N64 G3 X870. Y7.3 I102.7 J0.
N65 G1 X1515.
N66 G3 X1522.7 Y15. I0. J7.7
N67 G1 Y157.3
N68 G3 X1520. Y160. I-2.7 J0.
N69 G1 X1422.7 Y160.
N70  X1520.
N71 G3 X1522.7 Y162.7 I0. J2.7
N72 G1 Y510.
N73 G0 Z14.
N74 M13 S22000
N75  X1522.5
N76 G1 Z-0.3 F200
N77  Y857.3 F2000
N78 G3 X1520. Y859.8 I-2.5 J0.
N79 G1 X1422.5
N80  Y860.2
N81  X1520.
N82 G3 X1522.5 Y862.7 I0. J2.5
N83 G1 Y1005.
N84 G3 X1515. Y1012.5 I-7.5 J0.
N85 G1 X870.
N86 G3 X767.5 Y910. I0. J-102.5
N87 G1 Y110.
N88 G3 X870. Y7.5 I102.5 J0.
N89 G1 X1515.
N90 G3 X1522.5 Y15. I0. J7.5
N91 G1 Y157.3
N92 G3 X1520. Y159.8 I-2.5 J0.
N93 G1 X1422.5
N94  Y160.2
N95  X1520.
N96 G3 X1522.5 Y162.7 I0. J2.5
N97 G1 Y510.
N98 G0 Z14.
N99 M13 S25000
N100  X1522.7 Y1520.
N101 G1 Z1. F200
N102  Y1867.3 F2000
N103 G3 X1520. Y1870. I-2.7 J0.
N104 G1 X1422.7 Y1870.
N105  X1520.
N106 G3 X1522.7 Y1872.7 I0. J2.7
N107 G1 Y2015.
N108 G3 X1515. Y2022.7 I-7.7 J0.
N109 G1 X870.
N110 G3 X767.3 Y1920. I0. J-102.7
N111 G1 Y1120.
N112 G3 X870. Y1017.3 I102.7 J0.
N113 G1 X1515.
N114 G3 X1522.7 Y1025. I0. J7.7
N115 G1 Y1167.3
N116 G3 X1520. Y1170. I-2.7 J0.
N117 G1 X1422.7 Y1170.
N118  X1520.
N119 G3 X1522.7 Y1172.7 I0. J2.7
N120 G1 Y1520.
N121 G0 Z14.
N122 M13 S22000
N123  X1522.5
N124 G1 Z-0.3 F200
N125  Y1867.3 F2000
N126 G3 X1520. Y1869.8 I-2.5 J0.
N127 G1 X1422.5
N128  Y1870.2
N129  X1520.
N130 G3 X1522.5 Y1872.7 I0. J2.5
N131 G1 Y2015.
N132 G3 X1515. Y2022.5 I-7.5 J0.
N133 G1 X870.
N134 G3 X767.5 Y1920. I0. J-102.5
N135 G1 Y1120.
N136 G3 X870. Y1017.5 I102.5 J0.
N137 G1 X1515.
N138 G3 X1522.5 Y1025. I0. J7.5
N139 G1 Y1167.3
N140 G3 X1520. Y1169.8 I-2.5 J0.
N141 G1 X1422.5
N142  Y1170.2
N143  X1520.
N144 G3 X1522.5 Y1172.7 I0. J2.5
N145 G1 Y1520.
N146 G0 Z14.
N147 M13 S25000
N148  X762.7
N149 G1 Z1. F200
N150  Y1867.3 F2000
N151 G3 X760. Y1870. I-2.7 J0.
N152 G1 X662.7 Y1870.
N153  X760.
N154 G3 X762.7 Y1872.7 I0. J2.7
N155 G1 Y2015.
N156 G3 X755. Y2022.7 I-7.7 J0.
N157 G1 X110.
N158 G3 X7.3 Y1920. I0. J-102.7
N159 G1 Y1120.
N160 G3 X110. Y1017.3 I102.7 J0.
N161 G1 X755.
N162 G3 X762.7 Y1025. I0. J7.7
N163 G1 Y1167.3
N164 G3 X760. Y1170. I-2.7 J0.
N165 G1 X662.7 Y1170.
N166  X760.
N167 G3 X762.7 Y1172.7 I0. J2.7
N168 G1 Y1520.
N169 G0 Z14.
N170 M13 S22000
N171  X762.5
N172 G1 Z-0.3 F200
N173  Y1867.3 F2000
N174 G3 X760. Y1869.8 I-2.5 J0.
N175 G1 X662.5
N176  Y1870.2
N177  X760.
N178 G3 X762.5 Y1872.7 I0. J2.5
N179 G1 Y2015.
N180 G3 X755. Y2022.5 I-7.5 J0.
N181 G1 X110.
N182 G3 X7.5 Y1920. I0. J-102.5
N183 G1 Y1120.
N184 G3 X110. Y1017.5 I102.5 J0.
N185 G1 X755.
N186 G3 X762.5 Y1025. I0. J7.5
N187 G1 Y1167.3
N188 G3 X760. Y1169.8 I-2.5 J0.
N189 G1 X662.5
N190  Y1170.2
N191  X760.
N192 G3 X762.5 Y1172.7 I0. J2.5
N193 G1 Y1520.
N194 G0 Z14.
M30
all i can do at the machine is change F / S and a Z value  .
there is no real tool management at the machine, only a length measure
I make the nc-file with Enroute.
Regards
carlo
Message 4 of 9
seth.madore
Looks pretty standard fare ISO g-code. You can start with the RS-274D post processor or even the Fanuc post. The one difference I saw was that instead of an M3 for spindle control, you are using an M13. That's an easy change. You also have a hard Z return value and no G28/G53 moves or G43 Hxx codes.
When editing the post processors, I really love using the VSC plugin that ADSK developed. It makes finding particular code (and it’s corresponding output) very easy.
Seth Madore
Message 5 of 9
JonasDM46
Enig succes met de postprocessor voor de Cosign machine ?
Message 6 of 9
ferranti_boy
Goede morgen
de nieuwe machine's van cosign werken met de controller van Edingcnc
wat extra regels in de post zetten dien cosign gebruikt om de de machine te sturen en dan werkt het
zij hebben 2 subroutines die in de post moeten ingewerkt worden nl een sub Header en een Endsub
de post was van een oudere cosign machine die met een andere controller werkte
ondertussen hebben we een nieuwere machine
Message 7 of 9
JonasDM46
Ja, klopt. Die post heb ik inmiddels in orde gekregen en werkt perfect.
We hebben wel nog een oudere staan met de Sensa2000 sturing welke ik ook werkend wil krijgen met Fusion 360, vandaar mijn vraag of u een werkende post processor had zodoende ik mij het werk kan besparen om de post te schrijven.
Message 8 of 9
ferranti_boy
goeie morgen
heb nooit met fusion en de sensa sturing gewerkt
op het moment dat ik er mee wou beginnen heeft de baas beslist om een nieuwe machine aan te kopen (teveel problemen met de sensa sturing hardware matig)
dus iets verder mee gedaan
als ik iets moest maken dat ik in fusion had getekend heb ik dat even omgezet en dan met enroute  een prog gemaakt
baas werkt kent enkel draftsight en enroute
dus 99.9% van de tijd werk ik er ook bij
dus sorry geen oplossing voor u
maar ik denk dat seth madore wel in de goede richting aan het denken was
mvg
carlo
Message 9 of 9
JonasDM46
Bedankt voor de info.
Heb de post processor inmiddels zelf herschreven en werkt nu perfect met de sensa sturing.
