- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm making a classical guitar bridge on a CNC Shark using one of the post processors found on this forum (I believe it is a tweaked version of Seth Madore's).
I post processed the tool paths and they ran fine. I later went in and tried to optimize the toolpaths and machining time a bit. I copied the setup (maybe duplicated, I don't remember which), and reworked the settings, then PP'd the tool paths and they won't run on the machine. The old TAP files run fine, and even new files made from the original setup run OK. Is there some setting that I'm missing?
I've attached the f3d file, you can see the two setups, the old one called "Works OK" and the 2nd called "Optimized".
Any help is much appreciated
