2D contour hole leaving material on wall
infinite.machinery
infinite.machinery
For some reason one of the 2D contours for a hole is leaving material on the wall and not finishing the hole to the defined diameter. All the other hole in the project are fine. What could be causing this? I have compared this tool path with the others and I can't see anything obvious that would be causing this problem.
I changed compensation to "wear", it ran as expected, then changed it back to "in computer" and problem went away, no idea why.
infinite.machinery
Thank worked on my end also. Thanks!
Would be nice to know why this strange behavior occured.
What caused it ? .... full moon or a bug, you should probably report it for review.
daniel_lyall
@seth.madore Please have a look at this thank you.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
seth.madore
Indeed...
When I regenerated the toolpath, the issue went away, no need to switch to Wear and then back to Computer Compensation.
Couple of comments though on the toolpath; It's not really necessary to use both Multiple Depths AND Ramping. You can get this toolpath done with just the Ramping turned on, resulting in a shorter cycle time. Secondly, you could also just use the Bore toolpath
Seth Madore
