Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Comments are Duplicated in G-code
amasters
amasters
See both screenshots. I enter two comments into the program on Fusion. I'm using two comments due to the character limit that seems to cut off at ~80 characters.
When I look at the G code in a text editor or on the Haas machine, I see that the comments are duplicated.  Why?
I don't think I have seen this before, so its relatively new.
Using Haas Nextgen postprocessor 44145
Any help would be appreciated.
a.laasW8M6T
Hi
I'm not sure about the manual NC issue
Probably a better way to do this is to add those notes as setup notes
then add a section in the post processor
// output setup notes
 if (getProperty("showNotes")) {
 writeSetupNotes();
Where you want those output.
Andrew Laas
Senior Machinist, Scott Automation
amasters
Andrew,
That was very helpful. You have unlocked a new feature for me. Thanks!  I will be using this method from now on to post comments for the Operator.
Still not sure why that program was double posting the NC comments tho. But your method is better.
a.laasW8M6T
You can also add notes to toolpaths the same way,
No post modifications needed for that one as its already included in the stock posts
Andrew Laas
pkomatlapalli
Hi @amasters ,
Did the information provided by a.laasW8M6T help you and answer your question?
If yes, please consider marking it as the "Accepted solution" button. Doing so helps other community members quickly identify the most relevant answer and serves as a useful reference for users facing similar issues.
Pavan Kumar | Community Manager
Laurens-3DTechDraw
In the Setup name I see OP 2 2X, I assume the 2X means you have it set to run 2 parts? Meaning all the operations are being run twice and ordered (depending on the setting). So the first thing it does it outputs the comment twice.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
