Cloud posts missing every day
jason.collins
Message 1 of 9
jason.collins
Every morning I try to post all my post are not showing up. When I look in my asset folder they are there.  I have to then move to a different folder and then download to my computer, then upload back into assets folder. why do I have to do this every morning?  I need it in my cloud so I can work from different computers.
Replies (8)
Message 2 of 9
jeff.pek
Hi -
I don't know what would make them disappear, but you should be able to force a re-sync (which should stick) from the Cloud folder, using the following steps (assuming you're on Windows):
1. Shut down Fusion
2. In Explorer, navigate to the directory %localappdata%\Autodesk\Autodesk Fusion 360\<userid>\W.Login
3. Rename (as a backup) the "M" folder to something different.
4. Restart Fusion
This should, then, create a new "M" folder with the contents of what's in the various folders in the Assets project.
Jeff
Message 3 of 9
jason.collins
Jeff,
I did that and when i restarted Fusion it did not create a new M folder. I opened the the old M folder and it was empty.
Message 4 of 9
jeff.pek
Hi - Can you check of Enable Cloud Libraries is checked in the Manufacture section of Preferences?
  Jeff
Message 5 of 9
jason.collins
Yes, it is enabled. I copied my post and pasted it in the folder, and now when i check the Asset folder it shows that it is updated with today's time.
Message 6 of 9
jeff.pek
Hmm. Not sure what might be happening. Are you able to share your diagnostic logs with me?
You can e-mail to jeff DOT pek AT autodesk DOT com.
  Jeff
Message 7 of 9
jason.collins
Working on it. Our Firewall is blocking it from going out at the moment.
Message 8 of 9
jason.collins
It now says that you guys have rejected it. I can attach it here if need be.
Message 9 of 9
jeff.pek
Can you send me an e-mail with your e-mail info? I'll set up a shared folder where you can upload it.
  Jeff
