Chamfer direction change, turning
Paul_NextMedicalDesign
Message 1 of 11
Hello all,
I am using the turning chamfer function to slip it into the design without changing the model....first time I've tried it.
Question:  it appears that for my outside chamfer, it created a path "front to back".  Any way to change it to "back to front"?  If you read the pop-up help, it speaks about "direction-see below" (see PDF attachment)...yet I can't find it.  What am I missing?
Paul
EDIT:  wrong pop-up, look at the CHAMFER2 PDF
Replies (10)
Message 2 of 11
mike.mattera
Hi Paul_NextMedicalDesign,
It not so much that it's cutting Front to Back, as it's cutting outside to inside. If you're cutting chamfers on an inside profile, it cuts from the inside to the outside.  If you look at the example in the ToolTip graphic, cutting the opposite side of the OD Groove, It will be cutting Out to In, but also Back to Front. The main reason for this type of cutting direction is because it's the proper way to use that tool. You dont want to pull up with the tool to make a cut. You always want a downward force at the cutting tip.
Hope that explains it.
Message 3 of 11
Hi Mike,
Thanks for taking the time to comment.....
It might be semantics (but I don't think so).....my simulated and actual tool path for this external chamfer shown in the PDF goes first along the green line, and then chamfers on the blue line (and of course approaches and  retracts on the yellow).  I call this inside-to-outside and more importantly, we are in agreement this is the wrong way to take off a burr (in most cases).  I either have a check-box flipped which I can't seem to find (see previous comment about "direction")....or its a bug?
Thanks for investigating.
Paul
Message 4 of 11
mike.mattera
Red Arrow is the start of the cut.  Red, Yellow, Blue, Yellow, Green.
The tool is sitting at the end of the cut in the picture.
Message 5 of 11
Hi Mike,
I am not really following you.....do you mean the pop-up?  Regardless of what that graphic says, if you look at my part path, the tool goes green line first then blue....which is not what I want it to do.  Again, I think we agree on the goal, Fusion is not doing it.
Paul
Message 6 of 11
Is there an answer already, i have the same issue here.....
Message 7 of 11
roaldseelt,
No, I never got this work.  I assume it is a bug.  I gave-up making chamfers through Fusion and I make them in my model first.
Message 8 of 11
akash.kamoolkar
I've created a ticket for this feature request.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Message 9 of 11
Any progress with this - I came across it today. It's been over a year from what I see - will this BIG bug be ever solved? Please let me know - it is urgent. Thanks in advance.
ms
Message 10 of 11
akash.kamoolkar
@Anonymous we're actively working on adding the ability to reverse the chamfer direction as we speak.
Akash Kamoolkar
Akash Kamoolkar
Message 11 of 11
Hi Akash,
Thanks for the info - looking forward to having this functionality, because right now it only cuts the wrong way - exactly like Paul mentioned in 2017 🙂
ms
