- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hey everyone. i'm having issues generating a 'safe' toolpath to cut 0.6mm fretslots for a guitar fingerboard with a 0.5mm bit. i'm cutting this in super hard ebony so need to go realy slowly and avoid breaking the tiny mill bit which is really expensive. i've done this many times before and usually it goes ok and haven't broken a bit in a while but still would love to be as safe as possible.
So if you look at the fretslots toolpath there is two things i don't understand:
1. i don't understand why the toolpaths look so differently for the different slots, especially there is one in the middle which has a lot of retracts. The slots are pretty much exactly the same, same depth, same width just slightly different lengths.
2. Then i just can't get rid of the rapid stock collisions, i tried changing almost all parameters but there seems to be no way to avoid those collisions. Tried different ramps, tried using only high feed rate instead of rapids, and played around with all settings but still i'm getting these errors. Maybe another strategy would be safer for cutting these slots but 3d contour seems to be the only one that will give me the arched/curved bottom of the slots.
if anyone has any ideas on this that would be great.
cheers
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
