Multi-Axis Contours - Help
biuro2VD47
biuro2VD47
Community Visitor
Community Visitor
Hi'
How to correctly create a surface to be able to control the tool and avoid collisions? The cutter is set
perpendicular to the edge. How can the angle be changed to control the tool? Can this not be done in the 'Advanced Swarf' operation? If not, how can it be done?
a.laasW8M6T
Hi
You can use Manual Synchronization to control the tool axis along various parts of the contour, use sketch lines or edges to define
oleg.tikhomirov
Hi@biuro2VD47
You can also try Tool Axis Limits option in Multi-Axis Contour.
Oleg Tikhomirov
Software Engineer
