CAM Trouble with updated feature "Avoid/machine surfaces"
artisticdirection
Message 1 of 8
artisticdirection
Hello. Can anyone help with the new updates to "avoid/machine surfaces" under 3D parallel CAM settings? Ever since the latest software update, I am unable to get the tool to completely avoid certain selected surfaces. (See my pics)
Im using a .25" ball nose end to finish this guitar neck. The tool continues to rise up an over the "non selected" flat areas of my part.
Replies (7)
Message 2 of 8
seth.madore
Give it some Axial clearance on the  "Avoid" group. Result:
Seth Madore
Message 3 of 8
artisticdirection
I dunno, there has got to be a better way. It worked perfectly before the update
Message 4 of 8
programming2C78B
this way is better when you learn it. Select a new group, set it as avoid, and don't forget you can still use Boundaries.
Please click "Accept Solution" if what I wrote solved your issue!
Message 5 of 8
artisticdirection
I get the same results. I already had a group that was set to avoid, but the tool still rises up and over the boundary to avoid. How do you use boundaries? I don't understand why this is so difficult now.
Message 6 of 8
programming2C78B
Contact point boundary should be enabled about 99% of the time you are surfacing!
Then set it to tool center
Message 7 of 8
artisticdirection
Thank you. I tried it and got these strange loop jumping lines a the top edge of the part
Message 8 of 8
programming2C78B
That comes from your tolerances and avoid distances.
