CAM Simulation won't show points on toolpath
Benjamin-Schaefer
Message 1 of 9
Benjamin-Schaefer
Hallo,
im CAM-Modul von Fusion wird bei mir seit kurzem in der Simulation auf dem Werkzeugweg nicht mehr die Punkte angezeigt.
Wie kann ich das beheben?
Gibt es irgendeine hintergründige Einstellung mit der ich das versehentlich deaktiviert haben könnte?
Viele Grüße und Danke im Voraus für die Hilfe
In the CAM module of Fusion, I can't see the points on the toolpath during simulation anymore.
How can I fix this?
Is there any underlying setting I could have accidentally disabled?
Best regards and thanks in advance for the help
Benjamin
Replies (8)
Message 2 of 9
Marco.Takx
Hi @Benjamin-Schaefer,
Try to restart Fusion360 by using right mouse click -> Run as Administrator.
See if that helps you.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 9
Benjamin-Schaefer
Hello @Marco.Takx,
I tried your suggestion. Unfortunately it did not work.
Greetings Benjamin
Message 4 of 9
Marco.Takx
@Benjamin-Schaefer
I'm using Fusion 360 Ultimate and I don't have that specific problem.
Do you have it only in this specific file or in all files?
What I know at the moment that there are some issues with the UI caused by Windows Updates.
See the command of Phil.E
Marco Takx
Message 5 of 9
Benjamin-Schaefer
@Marco.Takx,
I'm using standard Fusion. The problem occurs only on my Win7 PC. On my Win10 PC everything is fine.
Message 6 of 9
Stuart-H
bet its your graphics card and or drivers on the windows 7 PC as you state its fine on W10
Mac Studio M1Max and MacBook Pro M1
Message 7 of 9
Lonnie.Cady
@Benjamin-Schaefer
Also make sure your camera angle is set to orthographic and not perspective.  They won't show up in perspective or perspective with ortho faces on my machine
Message 8 of 9
LibertyMachine
I think @Lonnie.Cady hit the nail on the head. No points show up for me in either of those other modes
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 9 of 9
Benjamin-Schaefer
@Lonnie.Cady
Thank you very much! This solved the problem. Seems like a bug and not intended.
