CAM machining times are not displaying
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
After last weeks January 9th update I have had a problem in CAM. My cycle times are not consistently displaying.
Almost all operations display as 0:00:00. Sometimes they display the correct times. Sometimes the same operation in two different setups in the same file will have the correct time for one and zero for the other setup. Some setups have all zeros and some have a mix of zeros and times.
They all display the correct time if I right click and choose to view the machining time.
It doesn't matter if I use a pre-existing cloud tool or create new tools, I get the same results.
I also lost many of my default settings for things like stock to leave, tolerance, and step overs, etc.
I have tried logging in and out and changing the settings in my preferences and have not had any luck fixing the machining time issue.
Any suggestions are appreciated!
Thank You,
Jon Bancroft
