Post process setups of linked files from assembly file.
JYZMT
JYZMT
I have a large ish file . It might have 30 medium complicated files linked into it.
In each of the 30 files, the cam space processes are all set up, and they are working.
Is it possible to run a post processor on all the setups in all of the linked file, with out going into each and every file and running them from there? This would save me many many hours of tedious work
They are well organised files, and are all within sub folders, within the same project. If there was a way to post process all the setups of all the files in a given folder, this could be a work around.
If anyone has any suggestions, they would be gratefully received. Thankyou
seth.madore
No, you would need to go into each one and post them from there. I don't think I've seen this sort of request before. It is certainly not a common need, I don't think.
Hindsight being what it is; posting them out at the time of program creation would be the way to go
Seth Madore
JYZMT
Thanks for your prompt reply.
Yep, I thought this may be the case. I can see why accessing all the cam spaces of all the files in a single assembly file might be a complicated thing.
An automated script post processing all the files in a folder, feels much more achievable. I have asked this in the scripting forum, but it apparently its complicated by the cloud storage and access issues?
