Bug Report - Visibility Breaks Toolpaths
Steinwerks
Mentor Mentor
Message 1 of 10
Steinwerks
Chugging along just playing with some toolpaths in an assembly (oddly enough it was actually found in the Gearbox Complete sample) and had to check with one of my own parts:
It can be seen that not all part visibility triggers this but at least some do. Most annoying.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Replies (9)
Message 2 of 10
LibertyMachine
Woah, that is super annoying. I am glad that it didn't fully break the toolpaths (you CAN regen them and keep going) but I wouldn't want to be doing that long term. Good catch
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 10
Steinwerks
You're right, I should've said Invalidates Toolpaths, but hopefully this gets some attention.
@Steven.Shaw
Neal Stein
Find me on:
Message 4 of 10
Steven.Shaw
This is table flip worthy. Noted I will get something going to resolve this.
Steven.Shaw
Product Support Specialist
Message 5 of 10
LibertyMachine
I don't do a lot of assembly work. 99% of my CAM is done with a single piece on screen. However, I did have one back in August that involved a fixture and a part, as well as all the programs for both items. Changing visibility does not seem to have any effect on them. I'm curious what conditions led to this being the case for @Steinwerks
Sadly, I can't publicly share the part, but involved parties are more than welcome to hit me up and I'll get you what you need if any comparisons need to be made
lol@table-flip worthy
Seth Madore
Message 6 of 10
Steven.Shaw
Could you send that to me?
Steven.Shaw
Message 7 of 10
LibertyMachine
Sure, PM sent
Seth Madore
Message 8 of 10
xander.luciano
Thanks for catching this @Steinwerks!
That shouldn't be happening. I'm trying to reproduce this issue on my end but I can't get get the change in visibility to invalidate my toolpaths. Can you share the model with us please? I'd like to see how you have it setup. Soon as we identify a reproducible workflow we'll get this logged!
Thanks!
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Message 9 of 10
LibertyMachine
@xander.luciano
There is a faulty file in the CAM Samples, "Gearbox Complete". The toolpaths are already laid out and everything. Just turn on/off visibility and you will see it
Seth Madore
Message 10 of 10
xander.luciano
Alright guys, Thanks for pointing this one out!
Figured out the cause of the issue, and got this logged as CAM-5436.
The issue is actually with the joints in the model. It seems fusion during a visibility change, causes Joints to send out a transform change notification that invalidates the toolpath. Got it logged in the system now though, so hopefully the dev team can patch this one up! For parts with lots of operations (like the CAM example file), the regeneration time can really eat up a lot of time.
Here's a quick gif of the issue and the workaround.
Thanks for the info guys!
Xander Luciano
Xander Luciano
