Message 1 of 18
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I came across what I believe to be a bug, or at least an oversight in the CAM mirror feature.
Basically, I often use my cnc mill to cut out sheet metal parts which I then bend. Most of my work in done in/on aluminum. Aluminum should always be climb cut assuming a low backlash machine, which a CNC mill is given it's ballscrews. When I mirrored a toolpath, I got the original that was a climb cut, but the mirror was a conventional. I think this a bug. The screencast shows the issue.
