Blend, allowance Bug.
HughesTooling
Consultant Consultant
HughesTooling
It seems like blend is adding the axial allowance to the radial allowance and leaving twice as much on the sides. I've set both to 0.2mm and it's correct on the depth but you can see in the image below where the part on the right is done with parallel there's a step at the corner where blend takes over. I've attached the file. It seems that setting the radial allowance to 0 and the axial to 0.2mm give 0.2mm on the sides and bottom like I need.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
@seth.madore  Any thought on this one before it drops of the first page.
Thanks Mark
Mark Hughes
seth.madore
Sorry about that Mark, I'll dig into it. Been a busy week for me
(that is starting to sound like a broken record....)
Seth Madore
seth.madore
I've logged this as CAM-18055. I'll post back here when/if there is anything more to add. Thanks for bringing this to our attention!
Seth Madore
