Another Yasnac post questions
Current generic post is
(SPOT M3)
N30 M09
N35 T0005 M06
N40 S5000 M03
N45 G54
N50 M08
N60 G00 X1.707 Y1.413
N65 G43 Z0.6 H05
N75 G00 Z0.2
N80 G98 G73 X1.707 Y1.413 Z-0.0625 R0.2 Q0.0625 P100 F15.
Would like to have
T1
M6
(Spot Drill)
G00 G90 G43 G54 Xxxx Yyyy Zzzz Sssss H1
Zzzz F100
(D1 G41)  {if needed} Xxxx Yyyy F50
G82 G98 Zzzz F10 P300
paul.clauss
Hi @Anonymous,
Thanks for posting! I was able to add in a tool description comment line to the generic Yasnac post. I'm not sure that this is exactly what you are looking for, but it at least includes the Post Comments (from the Post Processor tab in the Tool Editor) when the tool is called out. This area is in the photo below, where it reads "Test test test."large.png
Hopefully this helps! I'm kind of new to editing posts, so be sure to test carefully! Let me know if you have any other questions.
Post is attached to this forum post.
Paul Clauss
Product Support Specialist
CGPM
Hi Autumn,
Here is my 3 axis post for a Yasnac J300/i80 on a Kitamura for reference.  I have been using it for about 18 months with no problems and totally trust it myself but no guarantees.  It looks like we have some of the same desire in how our code is posted so even if my post isn't right it should be a lot closer to what you want than the generic one.  One MAJOR flaw in the generic Yasnac post is the M3 command when rigid tapping, which my post has fixed.  I am in the process of adding a 4th axis to it so if you need this let me know.
