Yea they are good but they still aren't that cheap the inserts are probably like $100-200NZD and you also need a shank to screw them on. very handy for cutting a large range of threads though. that insert will cut from 3mm-4mm pitch or whatever that converts to in imperial(UN and metric share the same thread profile)
They do a smaller one too which I use a lot for cutting M18x1.5 threads
For UN and metric threads the PDO is normally (For an OD thread) the major - the pitch
For metric its really easy to figure out as the threads are designated by the pitch, whereas UN they are designated by TPI.
Its easy to convert though you just take the inverse to find the pitch so 1/12=0.0833333 pitch
so for the PDO you would enter 0.08333(you can just type 1/12 straight into the field in Fusion)
This may not be perfect though and depending on the threadmill you may need to adjust this to get the thread to gauge right.
Seeing as you are making both parts, you can threadmill the male thread first and then adjust the female thread to fit.
This wouldn't be best practice if you were making parts for a customer but if it's just a one off you can fudge it like that.
Andrew Laas
Senior Machinist, Scott Automation
