Adding a user property to post, property showing as unspecified
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've added properties before with no issue, but I'm going around in circles on this one.
I've added a placeholder property "wibble" to a post, with a definition. When it comes to post a program, the property is showing as UNSPECIFIED. I've tried hand typing, copy/paste & rename, setting the type to integer/boolean/enum.
I've double checked for typos and I'm just stumped now
properties = {
wibble: true, //test property
setToolLengths: true, //writes tool length probing to end of program
writeMachine: false, // write machine
writeTools: false, // writes the tools
preloadTool: true, // preloads next tool on tool change if any
showSequenceNumbers: false, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
optionalStop: true, // optional stop
o8: false, // specifies 8-digit program number
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
allow3DArcs: false, // specifies that 3D circular arcs are allowed
useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words
forceIJK: false, // force output of IJK for G2/G3 when not using R word
useParametricFeed: true, // specifies that feed should be output using Q values
showNotes: false, // specifies that operation notes should be output
useSmoothing: true, // specifies if smoothing should be used or not
usePitchForTapping: true, // enable to use pitch instead of feed for the F-word for canned tapping cycles - note that your CNC control must be setup for pitch mode!
useG95: false, // use IPR/MPR instead of IPM/MPM
useG28: true, // specifies that G28 should be used instead of G53
useG54x4: false, // Fanuc 30i supports G54.4 for Workpiece Error Compensation
useSubroutines: false, // specifies that subroutines per each operation should be generated
useSubroutinePatterns: false, // generates subroutines for patterned operation
useSubroutineCycles: false, // generates subroutines for cycle operations on same holes
useRigidTapping: "yes", // output rigid tapping block
// user-defined property definitions
propertyDefinitions = {
wibble: {title:"something", description:"something else", group:0, type:"boolean"},
setToolLengths: {title:"Write tool length setting", description:"Writes a tool length setting program after the main program", group:0, type:"boolean"},
writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", group:1, type:"boolean"},
showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
o8: {title:"8 Digit program number", description:"Specifies that an 8 digit program number is needed.", type:"boolean"},
separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
allow3DArcs: {title:"Allow 3D arcs", description:"Specifies whether 3D circular arcs are allowed.", type:"boolean"},
useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
forceIJK: {title:"Force IJK", description:"Force the output of IJK for G2/G3 when not using R mode.", type:"boolean"},
useParametricFeed: {title:"Parametric feed", description:"Specifies the feed value that should be output using a Q value.", type:"boolean"},
showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
useSmoothing: {title:"Use smoothing", description:"Specifies if smoothing should be used or not.", type:"boolean"},
usePitchForTapping: {title:"Use pitch for tapping", description:"Enables the use of pitch instead of feed for the F-word in canned tapping cycles. Your CNC control must be setup for pitch mode!", type:"boolean"},
useG95: {title:"Use G95", description:"Use IPR/MPR instead of IPM/MPM.", type:"boolean"},
useG54x4: {title:"Use G54.4", description:"Fanuc 30i supports G54.4 for workpiece error compensation.", type:"boolean"},
useSubroutines: {title:"Use subroutines", description:"Specifies that subroutines per each operation should be generated.", type:"boolean"},
useSubroutinePatterns: {title:"Use subroutine patterns", description:"Generates subroutines for patterned operation.", type:"boolean"},
useSubroutineCycles: {title: "Use subroutine cycles", description: "Generates subroutines for cycle operations on same holes.", type: "boolean"},
useG28: {title: "G28 Safe retracts", description: "Disable to use G53 instead of G28 for retracts.", type: "boolean"},
useRigidTapping: {
title: "Use rigid tapping",
description: "Select 'Yes' to enable, 'No' to disable, or 'Without spindle direction' to enable rigid tapping without outputting the spindle direction block.",
type: "enum",
values:[
{title:"Yes", id:"yes"},
{title:"No", id:"no"},
{title:"Without spindle direction", id:"without"}
