Adding a user property to post, property showing as unspecified
vworpi
vworpi
I've added properties before with no issue, but I'm going around in circles on this one.
I've added a placeholder property "wibble" to a post, with a definition. When it comes to post a program, the property is showing as UNSPECIFIED. I've tried hand typing, copy/paste & rename, setting the type to integer/boolean/enum.
I've double checked for typos and I'm just stumped now
properties = {
	wibble: true,  //test property
	setToolLengths: true, //writes tool length probing to end of program
	writeMachine: false, // write machine
	writeTools: false, // writes the tools
	preloadTool: true, // preloads next tool on tool change if any
	showSequenceNumbers: false, // show sequence numbers
	sequenceNumberStart: 10, // first sequence number
	sequenceNumberIncrement: 5, // increment for sequence numbers
	optionalStop: true, // optional stop
	o8: false, // specifies 8-digit program number
	separateWordsWithSpace: true, // specifies that the words should be separated with a white space
	allow3DArcs: false, // specifies that 3D circular arcs are allowed
	useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words
	forceIJK: false, // force output of IJK for G2/G3 when not using R word
	useParametricFeed: true, // specifies that feed should be output using Q values
	showNotes: false, // specifies that operation notes should be output
	useSmoothing: true, // specifies if smoothing should be used or not
	usePitchForTapping: true, // enable to use pitch instead of feed for the F-word for canned tapping cycles - note that your CNC control must be setup for pitch mode!
	useG95: false, // use IPR/MPR instead of IPM/MPM
	useG28: true, // specifies that G28 should be used instead of G53
	useG54x4: false, // Fanuc 30i supports G54.4 for Workpiece Error Compensation
	useSubroutines: false, // specifies that subroutines per each operation should be generated
	useSubroutinePatterns: false, // generates subroutines for patterned operation
	useSubroutineCycles: false, // generates subroutines for cycle operations on same holes
	useRigidTapping: "yes", // output rigid tapping block
// user-defined property definitions
propertyDefinitions = {
	wibble: {title:"something", description:"something else", group:0, type:"boolean"},
	setToolLengths: {title:"Write tool length setting", description:"Writes a tool length setting program after the main program", group:0, type:"boolean"},
	writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
	writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
	preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", group:1, type:"boolean"},
	showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
	sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
	sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
	optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
	o8: {title:"8 Digit program number", description:"Specifies that an 8 digit program number is needed.", type:"boolean"},
	separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
	allow3DArcs: {title:"Allow 3D arcs", description:"Specifies whether 3D circular arcs are allowed.", type:"boolean"},
	useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
	forceIJK: {title:"Force IJK", description:"Force the output of IJK for G2/G3 when not using R mode.", type:"boolean"},
	useParametricFeed:  {title:"Parametric feed", description:"Specifies the feed value that should be output using a Q value.", type:"boolean"},
	showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
	useSmoothing: {title:"Use smoothing", description:"Specifies if smoothing should be used or not.", type:"boolean"},
	usePitchForTapping: {title:"Use pitch for tapping", description:"Enables the use of pitch instead of feed for the F-word in canned tapping cycles. Your CNC control must be setup for pitch mode!", type:"boolean"},
	useG95: {title:"Use G95", description:"Use IPR/MPR instead of IPM/MPM.", type:"boolean"},
	useG54x4: {title:"Use G54.4", description:"Fanuc 30i supports G54.4 for workpiece error compensation.", type:"boolean"},
	useSubroutines: {title:"Use subroutines", description:"Specifies that subroutines per 	each operation should be generated.", type:"boolean"},
	useSubroutinePatterns: {title:"Use subroutine patterns", description:"Generates subroutines for patterned operation.", type:"boolean"},
	useSubroutineCycles: {title: "Use subroutine cycles", description: "Generates subroutines for cycle operations on same holes.", type: "boolean"},
	useG28: {title: "G28 Safe retracts", description: "Disable to use G53 instead of G28 for retracts.", type: "boolean"},
	useRigidTapping: {
    title: "Use rigid tapping",
    description: "Select 'Yes' to enable, 'No' to disable, or 'Without spindle direction' to enable rigid tapping without outputting the spindle direction block.",
    type: "enum",
    values:[
      {title:"Yes", id:"yes"},
      {title:"No", id:"no"},
      {title:"Without spindle direction", id:"without"}
vworpi
This appears to be a caching issue, the post mods aren't updating in the current file. If I open another file, my new property is there.
This has, unfortunately, lead to a much more serious error. All of my posts are now failing with the following error:
Error: Failed to set property 'wibble' to 'axial'.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Monday, July 29, 2019 07:03:04 PM
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1662): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1667): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1678): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1683): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1704): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1716): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1735): octal literals and octal escape sequences are deprecated
Warning(c:\users\max\appdata\local\autodesk\autodesk fusion 360\ygavkdpmju59\w.login\m\d20180911148240781\camposts\VMC05 - Doosan Mynx 5 Axis.cps:1742): octal literals and octal escape sequences are deprecated
Code page changed to '20127 (US-ASCII)'
Error: ReferenceError: axial is not defined
Error at line: 1
Stack dump:
@:0
Failed while processing global script.
vworpi
Problem persisted after a reboot, then Fusion insisted on an update. The update failed (!) and recommended a reinstall(!), which I had to do as Fusion would no longer start.
The reinstall appears to have cured my global script issue, things are posting again.
vworpi
I'm still having issues where properties from one post are populating another. Currently, I have a post for a 3 axis machine spitting out extraneous B positions. Nothing has been changed, machine configuration is still false. It just seems to be holding onto a value from a previous post run earlier today.
Run through my other 3 axis posts and they are doing the same.
My work PC was fine this morning, it only seems to happen on my home PC.
