Adaptive Clearing wasteful extra motions and how can I optimize this carve?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
<Pardon is this post shows up twice, the first time I posted it it seemed to disappear>
I'm learning never to say "It could run more efficiently, but I'm only planning to carve a couple of them so it doesn't matter". Last Summer I designed a workshop sign and I just can't seem to stop myself from giving them away.
I originally did a 2 stage carve with this design (1/4" straight bit followed by 1/8" ball nose), but switched to just using the 1/8" ball nose because it didn't make much difference and was less fuss with my X-Carve to not change bits. So I'm doing a 3D adaptive clearing followed by a parallel finish pass with just the 1/8" ball nose.
What I'm seeing during the adaptive clearing operation is lots of vertical lifts and cutting moves which don't really seem to be cutting anything and are wasting lots of time.
This 2 minute video shows this at 30 seconds and 75 seconds in. I've seen the same behavior with straight bits, so I don't think it's any effect of the ball nose in the calculations. I can also see these moves in the CAM simulation and they don't appear to be cutting anything there either. I've tried changing a few operation parameters and haven't found anything that eliminates these.
I'm also looking for ways to make this carve go a lot faster, I think it's wasting a lot of time being fussy with the adaptive clearing which I've got set to leave 1mm extra material in both directions so the parallel pass has something to cut. In the attached picture you can see the parallel pass on the left and the adaptive clearing on the right and clearly the adaptive pass is doing more work than it should, but I haven't found any parameter changes that claim to speed it up much in the machine time estimate.
So far I've tried:
Just for the adaptive clearing operation:
starting machining time: 1:21:52
stock to leave from 0.5mm to 1mm: 1:09:16
tolerance from 0.1mm to 1mm: 1:08:09
minimum axial engagement from 0mm to 1mm: 1:08:09
minimum retraction policy: 1:06:25
Attached is an export of the project, can anyone give me ideas how to speed up the adaptive clearing while still using the one bit? This carve currently takes almost 6 hours of wall clock time despite the machining time estimate in Fusion of just a couple of hours. I think that lifts and travel moves on the X-Carve are a lot slower than Fusion estimates.
