A finishing issue
A finishing issue
adam.j.mclachlan
Message 1 of 22
A finishing issue
adam.j.mclachlan
Hi there, i am fairly new to fusion 360 and i was wondering if anyone would have any suggestions on how to finish this area shown below:
i have tried a few different toolpaths such as parallel, scallop and contour but it always contacts the back wall.
If anyone has any suggestions i would really appreciated them, thank you.
Replies (21)
Message 2 of 22
Richard.stubley
Hey @adam.j.mclachlan,
Id probably go for a scallop but use touch surfaces to only machine the areas I want. You also need to turn tool containment to outside.
Hope this helps.
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 3 of 22
adam.j.mclachlan
@Richard.stubley  I have just tried your suggestion but then the material i have left from the roughing Toolpaths is still there. I went back and used a contour Toolpath again and i got this:
This allowed me to machine all the excess material away from that face whilst getting rid of the majority of the material, do you know how i could change this to get that same tool path but to machine the top too? Thank you.
Message 4 of 22
Richard.stubley
Hi @adam.j.mclachlan,
Did running a scallop not work? is this what you are after?
Of course it sill needs the other features machining.
Richard Stubley
Message 5 of 22
adam.j.mclachlan
@Richard.stubley When i did the scallop Toolpath it cut from the bottom up and missed the areas at the top, whereas the contour Toolpath is cutting from the top down and machining and the faces i need it to do but missing a small section in the middle.
Do you have any ideas on how to get the contour toolpath to machine this small area in the middle? thank you
Message 6 of 22
Richard.stubley
@adam.j.mclachlan,
You wont really get around that with contour, as 3D contour is step up rather than step down. So imagine if you had a 1° inclined plane, even with a 0.1mm step up your step over is huge.
Can you send a screenshot of why scallop didn't work for you, I'm still not 100% the beauty of scallop is it keeps a nice consistent step over across the flowing geometry improving surface finish.
Richard Stubley
Message 7 of 22
adam.j.mclachlan
@Richard.stubley  so this is my scallop toolpath. i have messed around with it but this is all i could get.
I have changed it so the tool containment is set to on centre because when it was set to outside it would go down to the bottom of the part.
This is my geometry tab:
Message 8 of 22
Richard.stubley
@adam.j.mclachlan you will want to play with your bottom height and lift that up to restrict how low it cuts.
Hopefully you can see what I did in my project.
Richard Stubley
Message 9 of 22
adam.j.mclachlan
Okay i will thank you
Message 10 of 22
adam.j.mclachlan
@Richard.stubley  I have been messing around with different tool paths and i eventually tried the steep and shallow one. It has worked the way i wanted it to after a few adjustments.
The only thing i can see being a problem is the side of the tool rubbing on the part when its against the wall like this:
I thought of using an undercutting end mills like these ones:
Any suggestions you have would be appreciated, thank you.
Message 11 of 22
Your contour tool path leaves section of vertical wall that needs to be done with ball end mill along with corner fillet and curved surfaces. It is inevitable to hit that wall with full end mill length when surfacing fillet so what I would do is use 6 mm end mill instead of 1/8.
1/8 tool is too weak to be used at full length against vertical wall.
I added Trace with tool to the left side of geometry and purpose is to prep the vertical wall leaving .1 stock, running at lower feed rate.
Using Blend for more uniform passes, having only .1 mm of radial stock on vertical wall, tool should not have any chatter or break when it hits the wall while running over edge of fillet.
2020-05-19 18_27_42-Autodesk Fusion 360.png2020-05-19 18_35_48-Autodesk Fusion 360.png
EDIT:
After uploading edited file I noticed that contour tool path rounds the edges of chamfers, I turned on "make sharp corners", smoothing and feed optimization and didn't see any difference in outcome, you may wanna take closer look at that.
Message 12 of 22
mathew.hutton
I was going to suggest using steep and shallow as this toolpath was specifically designed for tackling geometry such as this. I have generated a toolpath that should work what you're after and you won't need to buy relieved shank tooling. All i did was specify the model geometry as the selected faces as shown in the attached image, i then specifed the avoid geometry as shown in the 2nd attached image. You can then see the outcome in the 3rd attached image. Hopefully this gives you what you're after and you won't need to purchase special tooling.
Mat
Mathew Hutton
Manufacturing Specialist
Message 13 of 22
adam.j.mclachlan
Hi @mathew.hutton, i had previously tried what you suggested but i did it again just to make sure i wasn't missing anything but the problem is it doesn't cut the excess material at the top so when it is cutting down the bottom the shaft of the tool is cutting instead of the bottom like this.
This is where it would only cut so far:
and this is it cutting with the shaft:
I will keep trying different methods, but thank you, its appreciated.
Message 14 of 22
adam.j.mclachlan
Hi @Anonymous, so do you suggest i use the trace and blend with a 6mm Ball before using a the steep and shallow toolpath? Or should i just solely use the trace and blend? thank you
EDIT:
I just tried to replicate your toolpath but it won't let me use the blend feature because i am using a student license, do you know any other method i could use? thank you
Message 15 of 22
I played with Steep and shallow with Parallel but could not get tool to start at top of the model and work its way down. As a result it hits vertical wall at the end of each pass over curved surface then feeds upwards to top of the model.
That is ineffective in gradually taking out stock left by rougher, not the best choice.
I was under impression that everyone has access to same options, turned on in preferences, but if you don't have Blend you can use Scallop or Parallel.
I don't particularly like Scallop in this case because it divides selected surfaces into sections, starts on outside edges and finishes in the middle, I like end to end tool passes better.
The advantage of using Trace is that you can take balk of the stock from vertical wall in one pass at low feed rate, even use two passes with radial stock to leave tailored to conditions, such as material type,  then let Scallop, Blend  or Parallel swing away without any ill effect on tool or finish each time tool kisses vertical wall with full length of flutes which is evident on each side of selected machining area.
By using same tool to do Trace and profiling, you can leave as little as .0005 stock to blend with corner fillet and finish tool path.
You have to pick one way of finishing that has best result, going over it with another strategy is not necessary.
As far as tool size, you wanna use tool that has radius just under the size of smallest fillet, so 6 mm is a lot stronger then 1/8 and it counts when tool meets vertical wall at its longest stretch.
Here is my experiment with Steep and shallow, which I don't like. file attached.
Message 16 of 22
Are you saying you don't have this ?
Message 17 of 22
adam.j.mclachlan
@Anonymous  i did not know that i had access to this, i had to agree and sign up to get access but i have it now, thank you.
As for the steep and shallow tool path i will set that aside just now and use the trace to clean up the wall section and then use the blend to finish the rest. Do you have any suggestions for the speeds, feeds, depth of cut and overlap for the 6mm ball when using the trace and blend toolpaths, thank you.
Message 18 of 22
adam.j.mclachlan
The toolpath you suggested @Anonymous  worked well thank you very much.
Message 19 of 22
I picked step over based on theoretical assumptions, you need to consider type of material, tool grade, surface finish, cycle time ........... and I don't have any of that info.
If you are running stainless steel duplicate Trace tool path and leave more radial stock on first one, making vertical wall clearing more gentle and gradual, leave .0005 to .001 radial stock on second pass for tool to finish along with blend for seamless finish.
Message 20 of 22
adam.j.mclachlan
@Anonymous i am just doing this for practice so cycle time doesn't matter. It will be aluminium with a carbide ball.
Another quick question, in the stock to leave for the trace you have put the axial stock to leave as -2.5. How did you know to put this value and not just zero?
