A axis profile on tube
jpblucasborean
jpblucasborean
I'm trying to do a profile on the A axis on the end of a tube. I can't figure out why the tool isn't staying top dead center but moves on both y and z as it is doing the profile. Should the tool not stay at the top of the part and the only movement should be on the A axis rotation and the X? I'm using the "multi axis" feature to try and do this. I have tried using advanced swarf and rotary contour but the result is the same.
seth.madore
A) What machine and control?
B) Is your WCS Origin set to center of rotation?
C) Does your machine have TCPC/DWO?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
jpblucasborean
I get the G255/G254 code in Fusion but my machine an older Haas vf4 goes into alarm if i try to run those in the code.
jpblucasborean
seth.madore
Seth Madore
