- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey Guys,
So Im trying to run a test piece on our Haas VF6 with a TR310 Trunnion. My issue is when I post and run the program, my tool paths seems to be 180 deg out on the Z Axis. Maybe my program is setup wrong, or something in my post file, Im not exactly sure. Here is what I have so far:
Setup
Tool Path for "6 Side"
So after I post and run the program on my machine.... My first 4 toolpaths work out perfect since they are only running 3 axis, but when I go to run the 5 axis portion here is what I end up getting as a result...
O01001 (Die Test)
(Using high feed G1 F500. instead of G0.)
(T1 D=3. CR=0. - face mill)
(T2 D=0.5 CR=0.25 - ball end mill)
(T7 D=0.375 CR=0. - flat end mill)
G90 G94 G17
G20
G53 G0 Z0.
(6 Side)
T7 M6
(.375" Cutter)
S8000 M3
G54
M11
M13
G0 A90. C-180. (C-Axis should be 0.)
M10
M12
G254
M8
G0 X-0.545 Y-0.5 (This should be X0.545 Y0.5)
G43 Z1.6 H7
T1
G0 Z1.2
Z1.132
G1 Z0.875 F1.019
X-0.5435 Y-0.4999 F300.
What am I missing here? Is it my post or is it my setup? I have DWO/TCPC on my Haas. The post Im using is the current Haas NGC post. Seems like no matter what I do, my tool path starts 180 deg off. Is my G254/255 in the wrong spot? If I turn on G234 I get an error in my machine. Hopefully everything I said makes sense. I have attached my .f3d file as well.
Thank you for the help!
Jim
