4th axis feed screw milling
Hello, i am trying to machine feed screw on 4th axis milling machine and so far i managed to do 2D contour that wraps around the part and does machining on walls of the screw. but i have no luck with roughing the part before that. i tried using 2D adaptive clearing with wrap function but i can't make it work. is it even posible to do it with 2D adaptive clearing or do i have to use some other strategy?
Thanks for help
vilts
That should be possible, I think.
Check out "4X Wrap - FSAE Hub" in CAM samples, it has some 2D adaptive wrapped toolpaths.
These files may give you few clues, note that to get walls done I used tapered end mill on one of them because end mill points to center of shaft in wrap operation and there is no way to correct for it otherwise.
Ops, responded to wrong post, meant for OP.
