45 cut atend of material
lvaszar
Message 1 of 9
lvaszar
I am trying to cut a 1x1" square aluminum profile with a 45 degree end cut. The setup is shown below. I will probe the x_min, y_max, z_max of the profile, then want the cutter (say a 1/2 end mill) cut the 45 degree face.  I am having a hard time setting up the cut. How would you do that? Thank you.
Replies (8)
Message 2 of 9
jhackney1972
I did it with multiple depth of cuts, you may want to change them.  Model is attached.
John Hackney, Retired
Message 3 of 9
lvaszar
Thank you, that works and I was able to replicate it. Just to make sure I understand the important thing here is to check "stock contour"? Without it the cutter wanted to go around the perimeter of the stock.
Message 4 of 9
g-andresen
Why don't you make such cuts with a saw?
günther
Message 5 of 9
seth.madore
@lvaszar no, you don't need Stock Contours or have to select the entire contour:
Seth Madore
Message 6 of 9
lvaszar
I cut the square ends to length with a band saw, but I don't enjoy fiddling and futzing with the saw angles and they are nowhere near as precise as cutting on a mill anyways; and it only takes 2 min on the mill. I really want these brackets to help an 8020 frame be square.
Message 7 of 9
lvaszar
Very helpful, thank you. When you select the contour, how come it does not select the whole perimeter of the piece? I see  that only the cut is selected. I don't understand how to do that.
Message 8 of 9
seth.madore
Huh, it appears that ScreenCast didn't capture my keyboard clicks. Press the ALT key and make a selection, it will select that single entity, not the full chain.
Seth Madore
Message 9 of 9
lvaszar
Thank you. Using Alt-click is the definitive answer, and I hope this will help some other noob like myself in selecting only one part of the contour.
