2mm contour with 2mm end mill not creating toolpath
MuesliReep
MuesliReep
I'm having trouble creating a toolpath for a 2mm endmill in a 2mm cutout using the 2D contour option.
I turned off the Lead-In & Lead-Out options. This let the toolpath generator generate toolpaths for most cutouts but not for all (See image below).
I have also attached the .f3d file.
LibertyMachine
As you've found out, you're going to have to lie to Fusion and say that either A) The slots are a little bigger than they are, or B) The tool is a little smaller than it is.
It cannot calculate a closed contour that it has to go into that is the same width as the tool. There are some workarounds by using the Trace command, but that's about it.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Steinwerks
@LibertyMachine is right.
Another workaround is to set the Stock to Leave at a very small negative value.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
LibertyMachine
even a blind squirrel finds an acorn once in a while 😉
The OTHER thing you could do (as if you didn't have enough options); Creatively selecting only a portion of the slot like this:
It may not come out the best, but then again, neither will slotting "to size" in most materials
Seth Madore
