2D pocket toolpath issue after update
Protective-foam_com
Message 1 of 21
Protective-foam_com
Hi everyone,
Three months ago, I generated a path that worked fine. Today I went back to this project and there is a problem with generating the path in several pockets even though I did not make any changes. I just loaded the model.fusion1.JPGfusion2.JPG
Changing the extension method doesn't help.
Has anyone encountered such a problem?
Replies (20)
Message 2 of 21
seth.madore
It's possible that something has changed in the toolpath calculation. Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 21
Protective-foam_com
Here you are;)
Message 4 of 21
seth.madore
The point of failure seems to be the Left/Right cutting method. I'm not sure of a solution (at this point), would it be possible to cut that one pocket in a Left (climb) manner?
Seth Madore
Message 5 of 21
Protective-foam_com
The workpiece is foam. Reversing the machining direction results in a jagged edge.
Is this problem related to the software update?
Message 6 of 21
seth.madore
Quite likely. The other very valid option is to use 2D Contour and turn on Roughing Passes:
Result:
 I'll get a ticket logged this morning as soon as some time frees up!
Seth Madore
Message 7 of 21
Protective-foam_com
I used a similar temporary solution.
I roughed a 2D pocket in the left direction and finished with a 2D contour.
Anyway, thank you for your help so far!
Message 8 of 21
engineguy
@Protective-foam_com
@seth.madore
Different "workaround" for this bug, instead of selecting bottom faces I tried selecting the bottom edges of all the pockets and this seemed to work quite well as it does the shallow pockets before the deep ones which would be logical, assuming you want to use pocketing IMHO 🙂 🙂
Example File attached.
Message 9 of 21
Protective-foam_com
@engineguy
But note that your example also has an error in the generated toolpath.
Similar as below:
In addition, with 650 pieces, it unnecessarily extends the processing time.
Message 10 of 21
seth.madore
Oh, I'm sorry, I skipped a step in my explanation. Program all the pockets that do work. For that one odd pocket, use the 2D Contour solution for that one feature.
Seth Madore
Message 11 of 21
Protective-foam_com
No, it's my mistake! @ was supposed to be to @engineguy (I have already corrected it).
Your post is clear to me 🙂
Message 12 of 21
engineguy
I did say that I was assuming you wanted to use the 2D Pocket that`s all 🙂 🙂
Have you tried the 3D Pocket Clearing ?? Might be better for this particular job 🙂
Message 13 of 21
Protective-foam_com
@seth.madore
The problem was not resolved during the last update. Do you know how I can report it directly to the support?
Message 14 of 21
engineguy
Yes, the issue does not seem to be fixed 😞
However, a "workaround" that I have found is to create a new pocket and it seems to work OK, still a great PITA but can be rescued.
It would appear that the original 2D Pocket is somehow "corrupted" and creating a new one works OK 🙂 🙂
Message 15 of 21
Protective-foam_com
@engineguy
The problem arises when you change the direction of machining to the right (conventional).
Message 16 of 21
engineguy
Works OK here, see images below and attached file.
I did make some changes to the entry method, ie, disabled the Leadin/out and changed the Helix Diameter.
I also selected the deeper pockets first and then the shallower ones and enabled the "Preserve Order" and the deep area is machined first so  the shallow areas can be done from outside the small area so it is plunging into air as the main pocket has already been cleared 🙂 🙂
Works for me anyway, does this help you ??  🙂 🙂 🙂
@seth.madore
Quite possible that some changes have been made to the 2D toolpaths and it is a matter of learning the new way, any ideas Seth ??
Message 17 of 21
seth.madore
As mentioned in your other thread, this issue has been logged as CAM-37410
Seth Madore
Message 18 of 21
Protective-foam_com
@seth.madore still this same...
How can this problem be escalated?
Message 19 of 21
seth.madore
@Protective-foam_com  The initial ticket has been fixed (back in June/July), but it's possible there are still outliers that present an issue. Please share your Fusion file here and I'll try to see what's going on
Seth Madore
Message 20 of 21
Protective-foam_com
Please, the file below.
