Message 1 of 9
2D contour
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi. Could you please help me? I’m learning how to machine a part in Fusion 360.
My problem is with the 2D Contour operation. I set several radial passes in X/Y with a 1 mm stepover, for a total of 5 passes.
However, Fusion first moves the tool directly to the final/finishing contour, so the cutter engages the full radial depth of cut. Only after that does it move outward and start making the passes with the correct 1 mm stepover.
I need it to work in the opposite order: start from the outside and gradually move toward the final contour, taking 1 mm radial cuts each pass.
What could be causing this? I’ve already tried many different settings but haven’t been able to solve it.
