2D Contour Maximum Stepdown confusion
billostratum
billostratum
I'm using a compression bit and need to step down to ensure the first cut is a down cut.
In the example shown (also uploaded) I have 20mm stock. I find that if I have maximum stepdown of 14mm, the two steps work as I expected. However, if I change the stepdown to 15 mm, I get "even" stepdowns instead of a 15mm step followed by a 5mm step.
Is there any explanation for why that is?
I know I can get the effect I want by working from the bottom with a 5mm finish stepdown, but it seems like I shouldn't have to do that calculation.
billoStratum
programming2C78B
you're right, that is the only difference. You can get around this by using a Finish Stepdown of 4mm. This will cut at -14 and then -18.
Please click "Accept Solution" if what I wrote solved your issue!
matty.fuller
I'm very curious about this behaviour too as it has stitched me up a few times on what I thought was a reliable template for a compression tool.
Looking at Compare & Edit in your file the only parameters that differ are the max roughing stepdown and max ramp stepdown. I played around with enabling ramping and entering different values, nothing I changed had any effect on the passes being generated evenly rather than taking the full depth of cut on the first pass.
billostratum
I've found that 14.4mm works, but 14.401 does not; 14.4 is exactly 80% of the desired full depth-of-cut.
It is almost like Fusion has an internal rule that says if your Maximum Roughing Stepdown is greater than 80% of the total, you didn't really mean that, and then automatically does Even stepdowns as a courtesy.
There must be a more logical explanation, with perhaps a workaround (other than converting to a Finishing Stepdown, as I pointed out in my original post).
Bill
billoStratum
oleg.tikhomirov
Hi @billostratum,
You are almost right. Fusion tries to avoid small stepdown at the end so it might make two last z stepdowns equal. It does not make all other stepdowns even.
There was very similar question some time ago: Solved: 2D pocket stepdown failure - Autodesk Community - Fusion 360
Oleg Tikhomirov
Software Engineer
billostratum
It seems more like a bug in that I can't use a compression bit without some unnecessary, and potentially error-prone arithmetic to calculate from the bottom instead of from the top.
billoStratum
billostratum
After struggling with this when varying stock thicknesses for different models, I realized the easiest solution is to simply create two separate contour operations: 1) for the high part of the contour that does a one-pass cut at the proper depth for the compression bit, and 2) another to complete to full depth using multiple passes (starting at a top corresponding to the compression bit.
billoStratum
