- Mute
- Permalink
- Report
I'm using a compression bit and need to step down to ensure the first cut is a down cut.
In the example shown (also uploaded) I have 20mm stock. I find that if I have maximum stepdown of 14mm, the two steps work as I expected. However, if I change the stepdown to 15 mm, I get "even" stepdowns instead of a 15mm step followed by a 5mm step.
Is there any explanation for why that is?
I know I can get the effect I want by working from the bottom with a 5mm finish stepdown, but it seems like I shouldn't have to do that calculation.
billoStratum
