2D adaptive rapid's into part
Message 1 of 16
I am using the Tormach post and in the gcode I rapdid into the part and I am not sure why.   See lines 120-140
Clearance is set to Origin +1.2
Retract is to set to Origin +.5
Top is set to Model top.   But I rapid all the way down into the part.
(POSTGRINDERTEST)
(T157 D=0.1875 CR=0. - ZMIN=0. - FLAT END MILL)
N10 G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
N20 G20
N30 G28 G91 Z0.
N40 G90
(2D ADAPTIVE1)
N50 M9
N60 M998
N70 T157 G43 H157 M6
N80 S4800 M3
N90 G54
N100 G0 X0.0069 Y-0.004
N110 M8
N120 G4 P2.
N130 G0 Z1.2
N140 G0 Z0.5
N150 G0 Z0.2379
N160 G1 Z0.2191 F12.
Replies (15)
Message 2 of 16
LibertyMachine
Is the top of the part supposed to be a positive .2379? How far was it trying to go past that point?
Would you mind exporting the .f3d file so we could take a look at it and see where things might have gone wrong?
To export: File, Export, Save to Computer on a location you know (I like desktop folder)
Come back to the forum and attach it
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 16
Steinwerks
A lot of this is going to depend on how you set up your heights, your entry, and the stock. This is not your post, it's the CAM. As @LibertyMachine said, it'd be necessary to see the part, or a dummy part to which you've duplicated the exact same toolpath.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 16
Smokeys
Sure, here is the part.   I've used another product for years and just trying to get into the Fusion360 way of doing things.
Message 5 of 16
Smokeys
The top of the part is supposed to be at .3, but I see it's a little higher that that.
Message 6 of 16
Smokeys
If I do 0 offset into the part I get this:
N130 G0 Z1.
N140 G0 Z0.5
N150 G0 Z0.2379
If I do .1 offset into the top I get this which is a little better, but I cut air for a while.
N130 G0 Z1.
N140 G0 Z0.5004
N150 G0 Z0.3379
N160 G1 Z0.3191 F12.
Message 7 of 16
Steinwerks
Because of the way you selected your pocket, the toolpath thinks you have a hole in the middle of the part into which to plunge (much faster than the helix entry). But you don't.
If you select the border edge of the bottom of your pocket as your Stock Contour it no longer makes this error and you can see the helix entry in red:
Here's what to select for Stock Contours:
Neal Stein
Find me on:
Message 8 of 16
Smokeys
That works.   I understand why and will add it to the thinks I need to check.
Thanks.
Message 9 of 16
Steinwerks
Thanks.
Could you mark that as a solution then so others who find this thread know it worked? Thanks, and glad it helped!
Neal Stein
Find me on:
Message 10 of 16
Hey Kevin and Steinworks,
We are having almost the exact same problem with generated gcode rapiding through our part (2 holes located an inch apart from eachother). The wierd thing is that it does not show the machine rapiding through the part in the simulation. Was this the same for you as well?
Message 11 of 16
Steinwerks
Can you share a screenshot of the part with toolpath in question?
Neal Stein
Find me on:
Message 12 of 16
Hey,
thanks for the response. Here are screen shots of the tool path as well as all the menus for the operations
Message 13 of 16
Here are the remaining menus it would not let me post more than 3..
Message 14 of 16
Steinwerks
Honestly I'd suggest starting a new thread since this isn't a 2D Adaptive issue. It's difficult to see what's going on exactly. Can you share the part or is that verboten?
Neal Stein
Find me on:
Message 15 of 16
Sounds good,
I would, but I cannot export the part because it has components that it references in CAM
Message 16 of 16
LibertyMachine
You can share the public a360 link that will allow us to download the full thing
Seth Madore
