10:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a deep (20mm) narrow (6mm) slot I'm attempting to cut using a 3mm straight end mill (21mm flute) and a 2D adaptive operation. I've set feed/speeds/WOC per HSMAdvisor recommendations (notably 0.4mm for Optimal Load, 1/3 of what F360 recommends), but I keep breaking tools (costing me ~$15.00/each and lots of runout optimization time).
Can anyone see any glaring mistakes I'm making in my setup? I've attached the model for reference.
HSMAdvisor settings:
Material: 6061-T6 Series Aluminum 95 HB Tool: 3.000mm 4FL Carbide None Solid End Mill Speed: 94.2 SMM/ 10000.0RPM Feed: 0.0133 mm/tooth 0.0533 mm/rev 533.40 mm/min Chip Thickness: 0.0133 mm Reference Chip load: 0.0267 mm Engagement: DOC=20.00 mm WOC=0.40 mm Effective Dia: 3.000 mm Cross Section: 0.89 x Dia. Power: 0.06kW MRR: 4.27 cm³ Torque: 0.06 N-M Max Torque: 0.14 N-M Cutting Force: 37.1 N Deflection: 0.19 mm Max Deflection: 0.27 mm Comment: Operation Comment: Additional Operation Info:
