Workflow modification using import tool
I would like the ability to update a section with workflow changes using the import section
This would be very useful when creating new sections
Always there are parts that are in different stages of any workflow and when a new section is created you can import the data, but you are not able to change the workflow by this method.
This means in some cases hundreds or thousands of parts need to be done one by one, a very time consuming method
5 Comments
nguyentru
Hi Mark,
I am trying to understand your request.
Let me try to summarize with my interpretation.
1.  Each section in the Item Details Tab, correspond to the appropriate Phase in the workflow.
2. You want to be able to import data into the fields in the Item Details Tab.
3.  Based on the populated fields, you want to move to the appropriate Phase in the Workflow.
Please verify if this is correct.
Trung
nguyentru
Status changed to: Accepted
Hi Mark,
Since this topic is over 6 months old, and we would like to review it in more detail internally in the context of Modern before potentially moving into a development backlog.
Giliar Perez
Product Owner - Fusion Lifecycle
Autodesk Canada Co.
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
