Simplify the payload needed for the API
The v3 POST/PATCH API to create/update an item is far more complicated than it needs to be…
To build the JSON for the update…
  1. I need to known which fields are in which section. It needs a call to get meta-data of the workspace.
  2. I also need to know the field types, this takes another call.
Field IDs are unique, so why do I have to tell the server which section a field is in?
But my question here is…
On the INTEGER, I can specify “5” as a string, and it is intelligent enough to accept this and cast to an Int. But only if the existing field is empty. Otherwise I get an error.
--> Can the API please be changed to provide this flexibility when there is an existing value?
It would generally save the second of the two calls above, and make it a bit more flexible?
[I'm expecting feedback about validity of json here. But in the example below, “link” and “fields” must be in this order. If “fields” is first, still valid json, then I receive a success 204 but the data is not actually updated !? ]
--> Can you please consider making an API that accepts a payload like this:
PATCH /api/v3/999/items/12345?easyPayload=true&ignoreInvalidFields=true&ignoreMissingPicklist=true
“DESCRIPTION”: “xx”,
“EXAMPLE_STR”: “xx”,
“EXAMPLE_INT”: “5”,  or 5
“EXAMPLE_DATE”: “2025-05-01”,
“JUST_IGNORE_THIS_IF_FIELD_DOES_NOT_EXIST”: “whatever”
“COUNTRY_PICKLIST”: “Something”,   … quietly ignore if no such value
“COUNTRIES_MULTI_PICKLIST”: ["UK", "USA", "France" ]
(Ideally URL fields rather than another ugly Content-Type header)
This would greatly reduce the complexity of the client code needed to make a REST call. Please consider this for the next API!
