A new functionality in F360M is released on August 14th, 2023.
Working version of revision-controlled items can now be reverted to match the latest revision. This is available for unlocked items, this means, Working Version will be reverted. This is a useful feature when many changes have been made and they are not needed and all changes must be set on the origin value. This means, that there is no need to compare or check the change log nesessary.
The big issue is. That any user can do this functionality. That is dangerous. There needs to be a way to set and control it.
In Revert Workflow action, it is solved with permissions. If you have not the permission to do it, the function is not available and it can not be done by the user.
Many user will test, what happen with the new function. So they will test it or will trigger it without consciously wanting to do it.
That any user can revert Workflow, is a big trouble. Permissions are needed for a better collaboration between different users.
