In the classic UI (don’t know about the MUI), it is not possible to add a parent from the tab “Where Used”.
The problem is when there is no item in the tab “Where Used” and we click on the “+” to do an “Expand All”, we are automatically redirected to the tab “Bill of Materials”… One of the user didn’t see the modification of tab and think that he was able to add parents items (the “Add” button of the tab BOM was visible). We correct the mistake but:
1/ Could you please fix the redirection issue?
2/ Could you please add a button “Add” in the tab “Where Used” directly?
It is normally possible because if we would like to add lot of parents to a child item, for the moment we need to go on the working revision of the child, click on “Create Relationships” on the top right-hand corner, select the workspace where are the parents, select BOM and then add all the parents. (This is possible if you have correctly defined your workspace relationships before as admin).
(A video was made to show you the problem 1)
Sylvain
