Insert row function in the grid tab
It would be great to be able to insert rows in a grid between two existing rows.  This would eliminate work arounds needed to sort a grid to get the information in the order desired.  If inserting rows becomes possible, then maybe moving rows would be possible as well.  It would be nice to have this type of functionality in a workspace to combine the power of excel-type functionality with the benefits of this PLM system.
1 Comment
I agree, this would be convenient. In the past to provide my clients this functionality, I've added an "Add to Bottom" checkmark field to the grid tab and written a script to copy the rows selected to add them to the bottom and then delete that row. The script has to be run on demand or with a workflow transition. It does essentially move rows to the bottom after you add the rows you need to insert. You could also number your rows with a field and then sort by the field.
