Would it be possible to enhance the import rules so that it is not required to import all fields of data in particular class when using the import tool.
Current behavior is that if I have class with in example ten fields, and I want to update only a one fields data using the import, I need to add those nine fields data into the import template. This is a must even if I do not any need to change the data content of those nine fields. If I do not include those fields they are going to be wiped empty the import, even if they are not included into the import template.
