Bulk Change/Update Owner
we should be able to Change the Owner of multiple records in one bulk change. currently we as admins can only change the owner of a record manually one at a time. we should be able to import the change to multiple records.
2 Comments
sven.dickmans
I support this idea.
In the meantime, as a workaround, you could use the Data Manager utility, enabling to batch-process any kind of data in your Fusion Manage tenant. It offers various actions, including the change of ownership:
You can see this utility in action here: https://youtu.be/hL4UblHbXw0?si=CILoMZYjlwKVfg5K&t=120
This is not an official Autodesk product, not even a commercial product, but an add-on which uses the Fusion Manage REST API in a custom built web application. I created this set of tools based on node.js and am sharing the sources at GitHub.. This is open source, so you can customize it as you needKeep in mind that there is no official support for this utility from Autodesk and that it is highly recommended to engage with your PLM implementation partner if you want to use this utility. You should also test this utility against your sandbox first.
I thought it would be worth sharing this information anyway, depending on the urgency of your idea/request.
richard.valdez
Thanks for the information, the system should have this function so we don't have to work with third party PLM implementation partners. this type of third-party work costs more money and the PLM system we already pay for should allow it.
