Modern UI Not Rendering Scripted HTML in item Fields
john.denner
john.denner
Switched over to Modern UI and Fields with scripted HTML (not calculated fields) are not rendering as HTML. They exact same fields work fine in Classic. The HTML does render correctly in grid fields.
Anyone else have this issue?
james.l.bryant
Hello @john.denner,
I recently reached out to you from case # 13869314 for specific details.  I'll update the forum post after review.   Thank you
James L Bryant
Autodesk Support Team
Contact Autodesk |
