How to default an Image in the Item Details to display during record creation?
Message 1 of 8
I am wondering how to add an image field (or calculated field) to display an image when a user is creating a record (i.e. before save). Is there a way to accomplish this?
Thanks!
Wendy
Replies (7)
Message 2 of 8
PLM-Sylvain.Bailly
Hi Wendy,
I don’t know if it is possible because my tests failed:
Test 1: Use a computed field
If you create a single line text field and use it as a computed field with a code like below, the image appears when you save your item and not in the creation phase.
'<img src="http://www.advancedoncotherapy.com/Portals/0/Logo.png" alt="AVO/ADAM" width="260" height="71">'
Test 2: Use a derived field
Same as the test 1 and this time you are forced to store in another [WS] the image and find a pivot field in the 2 workspaces.
Sorry
Message 3 of 8
I've used the computer field message mentioned earlier but it will not appear until you save the record.
Message 4 of 8
tony.mandatori
If the field is not updateable, then it should render the HTML.
It displays HTML code when it is updateable.
I haven't tried this recently - going on memory.  Please try setting updateable to false.
Message 5 of 8
tony.mandatori
I just mocked something up and it seems to work for me.
Days Left field is calculated and formatted with HTML and this is an edit screen...
2018-02-06 14_57_40-CO000020 - Change power supply layout - Fusion Lifecycle.png
Message 6 of 8
PLM-Sylvain.Bailly
It works also for me when you do an "EDIT" on an item which already exists. As you can see below, I have edited and item which contains computed fields "Risk Factor" and "Risk Factor Matrix" (the last one is an image).
(sorry but for confidential reasons I must hide most of the information but as you can see on the top, we are in "edit" mode)
But the question is "ON CREATE" if I correctly understand. So, it means that it is when you create the first time the item (click on the "+" on the top right hand corner).
Message 7 of 8
tony.mandatori
Thanks for pointing that out... you're absolutely correct!
Message 8 of 8
Thank you!
Yes, the On Edit approach worked for me with the example you provided. I guess it is a request for the future to have the image display during Create. Thanks again!
