Hello!
I'm having difficulty with a change order stuck in CCB approval, despite no remaining approvers. 4 of the 5 predefined approvers approved the CO, but the 5th approver left the company unexpectedly and his account was inactivated and removed from the approval list. The CO now appears to have full approval from all 4 approvers with the 5th removed, but I'm unable to actually implement it with no workflow actions available. Is there a way to force the CO to return or approve instead of sitting in limbo waiting for a nonexistent last approver?
Thank you!
The default approval board scripts reveal the last transition to the last approver only.
As an administrator, can you add another approver? This should reveal the transition to the added user allowing him to complete the workflow.
Let us know how it goes!
Thanks for the suggestion! Unfortunately, although I added another approver to the general CCB approval workflow, he wasn't added as an approver to this specific change order and was incapable of approving it. I can't seem to add any other approvers to this change order specifically either.
You have different options, some of them are better in the traceability point of view:
Advantages: No big modification and fast to do it.
Drawback: Security problem during the activation of a non-authorized account
Normally when you edit you must have a script ‘on save’ to update the new list of approvers. To see if you have this script you can go on “Administration > Workspace Manager” then click on the DCR workspace and select “Behaviors”. In front of the line “Script to run when item details are modified” you must have a script. To look what does this script, go in “Administration > System configuration > Scripting”.
If you want we can do a skype call to review the script together.
Advantages: A correct configuration with an update script on save
Drawback: any
Thanks for the help. The solution that worked for me, provided by Autodesk:
