muy buenas. tengo problemas para postprocesar en torno. en fresa me funciona bien. e probado varios postprocesadores y todos me da el siguiente error.
Information: Configuration: FANUC Turning
Information: Vendor: Fanuc
Information: Posting intermediate data to 'C:\Users\valery\AppData\Local\Fusion 360 CAM\nc\10016.nc'
Information: Total number of warnings: 3
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latín I)'
Start time: Sunday, November 3, 2019 7:24:16 PM
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Code page changed to '20127 (EE.UU.-ASCII)'
Post processor engine: 4.53.0 9
Configuration path: C:\Users\valery\AppData\Local\Autodesk\webdeploy\production\20eba7b8590bd15aa5cf30169381ceca41f2dc77\Applications\CAM360\Data\Posts\fanuc turning.cps
Include paths: C:\Users\valery\AppData\Local\Autodesk\webdeploy\production\20eba7b8590bd15aa5cf30169381ceca41f2dc77\Applications\CAM360\Data\Posts
Configuration modification date: Saturday, October 5, 2019 10:25:29 AM
Output path: C:\Users\valery\AppData\Local\Fusion 360 CAM\nc\10016.nc
Checksum of intermediate NC data: aa4df4937fc0cf24e3c6175280e9d6b8
Checksum of configuration: 5b4c881e4b59f516fb2380f79186cc3f
Vendor url: http://www.fanuc.com
Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
Error: Program number is out of range.
Error at line: 356
Failed while processing onOpen().
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to invoke function 'onOpen'.
Error: Failed to execute configuration.
Stop time: Sunday, November 3, 2019 7:24:16 PM
Post processing failed.
@Anonymous para una mayor claridad @joaquim.moral ha editado el título original: problema fusion 360. postprocesar para torno
Recuerda consultar cómo escoger el mejor título para tu post. ¡Gracias por participar!
¡Resuelto! Ir a solución.
Resuelto por JaumeMartinez. Ir a solución.
Hola, podrias compartir el archivo de fusion 360 para poder revisarlo y ver en donde esta el error al postprocesar?
Hola @Anonymous ,
Tal como te ha indicado @fnavarrop sería de gran ayuda que adjuntes el archivo de Fusion para analizarlo y encontrar el problema.
Según la lectura de error parece que estás utilizando un número de programa con demasiados dígitos o con alguno de ellos incompatible con la configuración del post-procesador. O al menos el error se encuentra en dicho apartado de número de programa.
Si puedes adjunta tu archivo y le echamos un vistazo.
Saludos cordiales.
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta | Please give me Kudos and mark this response as Accept as Solution if it answers your question
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
