Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Unable to create Circular Copper
0 REPLIES 0
Message 1 of 1
osamaolabi
204 Views, 0 Replies
I am trying to create a circle-filled copper in PCB electronics design. For some reason I just can not create another circle that is smaller than the big one to create a filled area. also I can not create any circle to be filled with copper. Only connected lines become filled with copper. is there a way to be able to create circular filled shapes?
attached are the photos and a test file. You will see I was trying different things to see what can get filled and what can't. In the second image, I show what I am trying to achieve, the black color is the PCB borders, red is the Copper outline and the purple is the filled copper. You can see when I tried this with lines it filled it perfectly, but with circles it just doesn't work.
Thank you so much for your help.
Tags (2)
Labels (2)
0 REPLIES 0
