Hi there,
The way to speficy single layer board:
Go to Document -> Layer Stack Manager -> By default, you will see the drop down list contains "2 layer Stack", click to open the drop down -> In last row, click "Open From Setup String ..." -> In the setup box, input "1" (top) or "16" (bottom).
Hope this helps.
Best,
Boyuan
I can't select Aluminium as a base. It is not the Material layer list. Many people use MCPCB's in the Led industry
Hi @FritsVuyk,
I hope this message finds you well. I'll put this in as a feature request. With that said you don't have to worry, you can still get your design done. The stackup information doesn't make it into the gerbers so the board house can use whatever stackup they prefer.
Let me know if there's anything else I can do for you.
Best Regards,
Just wondering if there is any progress in adding 1 layer metal-core's in the stackup
The feature request by Jorge is more than a year ago...
Hi @FritsVuyk,
I hope you're doing well. Nothing to report on this yet. I thought I had created the ticket but I couldn't find it. So I have made a new ticket and added details about the need for metal core substrates.
Best Regards,
