Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Skewed components on circuit/PCB design after rotation
4 REPLIES 4
adam_bellavance
188 Views, 4 Replies
I have some components on a PCB design that I have rotated using ROTATE R5. I click the object 6 times to get to 30^d.  I have tried ROTATE R30 to the same effect - a component looking like a parallelogram.
The rotated components come out skewed such that holding a right angle up to the screen a 16 pin chip is visually skewed by about 12mil, which would be enough to make the smd pads not line up. If I rotate back to a multiple of 90 it is fine again.
How this can be corrected?
4 REPLIES 4
CGBenner
in reply to: adam_bellavance
@adam_bellavance
Welcome to the forum, Adam!
@jorge_garcia any thoughts here?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Thanks for the welcome and ping.
I think the issue has to do with how Fusions visualizes 2D shapes. It's distracting but will not impact the final design will be impacted.  I used PRINT to verify the geometry.
Hello @adam_bellavance,
I hope you're doing well. Could you post a picture of what you are seeing? Monitors aren't the best way to judge the physical size of a component, you could go with a printout or the most accurate and reliable option is to generate gerbers and check them out in a gerber viewer.
Let me know if you are able to verify the output or if you have any questions or concerns.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
CGBenner
@adam_bellavance Do you still need help with this question, Adam?
Chris Benner
