I have an issue with a component that's rotated weirdly:
Those two switches are the same component, but the one to the right is rotated 90 degrees for some odd reason.
Autodesk support didn't help at all. They only said it might be because it's rotated wrongly in the library, and when I stated they were the same component, I didn't hear anymore. Not adequate support when paying for a product.
The component looks alright on the 2d PCB.
Edit: fixed right/left mistake
Solved by HelenChen-ElectronicsQA. Go to Solution.
Hi @pstormarkG9SGY ,
So sorry to hear that you're having trouble.
Do you mind inviting our development team into your Fusion team hub where able to access the 3D PCB as well as the library you used?
I will send private message to you soon for details.
Thank you so much!
Best regards,
Helen
Thank you so much for all your great help!
Hi @pstormarkG9SGY,
Hope all is well.
Good news that today we have an update about Fusion 360 version 2.0.16007 which has a fix about the issue you reported.
Could you please upgrade to latest to have a try? It should work for you now without any extra steps.
Thank you very much for your reporting and so sorry for any inconvenience.
Best regards,
Helen
